Discussion topic: Hayu activation issue
Message posted on 20 Apr 2026 07:00 PM
When i try to activate my hayu account it keeps coming up with this error 2003-0003-0012 - HTTP request failed with status 400
Message posted on 20 Apr 2026 07:54 PM - last edited: 20 Apr 2026 07:55 PM
Re: Hayu activation issue
Hi @Afahigfur A full subscription to Hayu will not be available until July so you would not be able to sign up through Sky until then (probably the cause of the error message). This a look at THIS Sky article under the paragraph headed "Top reality telly from Hayu on Sky"
There was a rail on the Sky homepage for shows that you can currently watch on Hayu but I can't see it any more.
Message posted on 21 Apr 2026 01:33 PM
The taste of Hayu rail moves from the main homepage rails, to Home>TV shows and is currently sitting under Home>TV shows>Reality.
