This discussion topic has been answered Discussion topic: Ent OS 1.3
Message posted on 29 May 2024 05:58 PM
Re: OS 1.3
@Fothergill1 wrote:
@Jporch316 wrote:
@Paul+Boland wrote:
Using the restart feature from settings takes longer than using power plug method
It takes abot 3 min to get to home screen menu.
Yeah ....
quite handy for those with a tv on the wall and the socket behind though
And at least we can change up the "pull the plug" comments to "press restart in the settings"!
Also handy when you are comfortable on the sofa or armchair 😀
My tapo smart plug is even better " Alexa ... sky glass off" .... "Alexa ... sky glass on "
Message posted on 29 May 2024 06:10 PM
Re: OS 1.3
Restart function won't be of any use if you have Sky Glass or Stream Puck freeze as in when you can't access any settings.
In that situation you will still need to use power plug method.
Message posted on 29 May 2024 06:43 PM
Re: OS 1.3
Good point @Paul+Boland
Message posted on 29 May 2024 07:49 PM
Re: OS 1.3
@Super+Anthony & @Paul+Boland in the rare circumstances where the pucks freeze then pull the ppwer as before but thst doesnt mean the new restart option isn't useful in other circumstances ie its an improvement.
Message posted on 29 May 2024 07:59 PM
Re: OS 1.3
Shame there isn't a voice command for the new restart function that would be super useful rather than having to go through the menus.
With the system being primarily designed for voice control that has surprised me a little bit.
Message posted on 29 May 2024 08:52 PM
Re: OS 1.3
@Chrisee You are right it is an improvement but @Paul+Boland has an excellent point should the machine freeze. You not going to be able to get to the menu if it frozen.
Message posted on 29 May 2024 08:54 PM
Re: OS 1.3
@Super+Anthony wrote:@Chrisee You are right it is an improvement but @Paul+Boland has an excellent point should the machine freeze. You not going to be able to get to the menu if it frozen.
Well that's the same for any of these electronic devices but at least like a lot of devices there is a way to invoke a restart through the UI now where you can.
To be honest I've found in the past 2 months I've had to reboot my stream puck a lot less than I had to in my first 4 months of it use.
Message posted on 29 May 2024 09:04 PM - last edited: 29 May 2024 09:25 PM
Re: OS 1.3
Agreed. I think we all have valid points and no one is wrong
Message posted on 31 May 2024 02:12 AM
Re: OS 1.3
I have had my sky glass TV and stream puck on standby every night since 1st may and still both have not received the 1.3 update.
Message posted on 31 May 2024 02:47 AM - last edited: 31 May 2024 03:08 AM
Re: OS 1.3
As I previously mentioned in post number 55
Sky updates are rolled out in batches over a few weeks it's depends on your devices MAC address and home address location.
Some customers Sky glass/stream pucks will get updated in June.
Software updates It's not unusual to see some customers mention they have got an update and others only get that update after another 2 to 4 weeks.
Message posted on 31 May 2024 07:19 AM
Re: OS 1.3
@Jon87 Further to the post by @Paul+Boland the update only started rolling out on the night of 28th May.
Message posted on 31 May 2024 04:21 PM
Re: OS 1.3
Am still waiting for my update, but like you say, its done in batches. Hope everyone is well
Message posted on 31 May 2024 04:26 PM
Re: OS 1.3
All good things come to those who wait. 👍
Message posted on 04 Jun 2024 12:29 PM
Re: Ent OS 1.3
One of our pucks has received the update overnight, weirdly the other three have not, other than the obvious change to movies page one thing I have noticed is that the low latency channel is not on 401 at the moment and still 922.
Message posted on 04 Jun 2024 12:37 PM
Re: Ent OS 1.3
Hi, can you post any photos showing any difference to the UI please or any other differences
