9
This discussion topic has been answered Discussion topic: Change Sky stream input name on AV receiver
This message was authored by: PSG
I connect my Sky Stream puck to my Denon AV receiver by the HDMI cable supplied by Sky. The receiver displays the input as "Sky TV". I can change it in the Denon app to be "Sky", but as soon as the puck is switched on, the name reverts to "Sky TV".
This matters to me because the display on the receiver only has enough space to display "Sky T". How can I change the HDMI name to "Sky"?
This message was authored by: 75sky Answer
Re: Change Sky stream input name on AV receiver
hi i changed the names on my denon and marantz with the remote on the AVR's setting and they aint chaged since maybe give it a try that way instead of the app
@PSG  Best to ask this in the AV Forums.
@PSG
A quick look online suggests that's different for various Denon AVR models. It's up to Denon what gets displayed: the Sky device will be presenting a standard code identification string.
This message was authored by: CoffeeDrinker
@PSG What model of Denon AVR are you using?
Using a Denon X3500H in the lounge here, with all the HDMI inputs manually renamed, so HDMI1 is 'Sky Stream', 2 is 'Apple TV', 3 is 'PlayStation 5' etc.
Lounge: Sky Glass gen 2 65” volcanic grey, Denon X3500H AVR. M&K K Series 5.1.2 speakers, PS5 Pro, Apple TV 4K, Sony X800 M2 4K player.
Bedroom: Sky Glass gen 1 43” dusky pink, Apple TV 4K.
Avatar for PSG
Thanks, I'll try that.
Avatar for PSG
Thanks. Maybe this cannot be fixed.
Avatar for PSG
I have a Denon AVR S670H.  I can change the input name on Denon, but it gets overridden once the Sky puck has been switched on. Annoying!
Avatar for PSG
@75sky Many thanks, that worked.
I would never have thought that setting the name by the remote would produce different results than the Denon app.
no problem glad it's sorted for you
Answered - Go to Answer
