14 Aug 2024 09:34 PM
When I watch BBC on sky stream it always buffers and stops. Any reason why?
14 Aug 2024 09:43 PM
Posted by a Superuser, not a Sky employee. Find out more@Carly2384 You can check the speed your puck is getting by opening the netflix app on the puck, go to Get hepp and run a connection test. If speeds are less than 25mbps then this will be the main issue.
15 Aug 2024 12:01 AM
@GD1 Thank you for response, i will give that a try
