Discussion topic: Re: Sky remote not working not batteries
This message was authored by: simplesi73
Mine is doing the same intermitently tv wont work says fault
There is no remote control for SKY GO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Which Sky System do you have?
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
3. Sky Glass & Live (Sky Glass & Live)
4. Sky Stream (Sky Stream)
Avatar for simplesi73
Puck box message on screen says fault but when i check on here for my services its says its all working.
I have moved your thread to a more appropriate forum
Not sure what this has got to do with the remote control - it doesn't sound like that is the problem.
Have you tried rebooting your puck?
If your device is on software version QS28:
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
If you don't have software version QS28 yet, then to reboot the device you need to turn it off at the plug for 2 minutes.
