Discussion topic: Trouble using Sky Store
This message was authored by Don70 This message was authored by: Don70
Why after I've entered all my details to try and rent a movie does sky store say an unexpected error has occurred. This has happened continuously for days.
Re: Trouble using Sky Store
@Don70
Ignoring this error for a minute, on what device are you planning to watch the rented title on ?
Don70
On my TV.
And this error is appearing via your TV/ Sky box/ Sky Glass/Stream ?
Don70
Via my phone that i used to access it.
@Don70
It is probably not a bad thing that this error appeared @Don70 because although you are able to rent using your phone, if you plan to watch it via your Sky Q box (I presume this is what you mean by TV) then you would not be able to as you can't rent on a phone and send the film to the Q box to view as you can only do this with a Buy and Keep film and not rented ones.
If you want to watch it via Sky Q then you have to rent it via your Q box.
Don70
In order to rent the movie you must use your phone.  The TV shows a qr code to access it.   When navigating to the sky site to access the movie I get the unexpected error message when I enter my last name.
As a result I'm unable to access any sky store content.    I'm unable to find any useful advice about what to do.
I'll be finding another TV and Internet provider when my contract is up if I can't fix this.
For your issue I would get in touch with Sky Store support regarding this, they have a live chat you can use that is available from 11am-7.30pm Monday to Saturday and can be found here:
https://www.skystore.com/help/contact-us
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@Don70 wrote:
On my TV.
Do you have Sky Q?
This message was authored by Sally_Ann This message was authored by: Sally_Ann
I'm having same issue. Interested to see if you resolved. I've tried the app, and two browsers on phone and same result.
This message was authored by RangerSi This message was authored by: RangerSi
Solved it...
The reason for the error is because you don't have a last name associated with your Sky Id, you need to add these details to your Sky account.
- sign in to your account at sky.com
- go to "My Details" and then "Manage Sky ID"
- click "Edit Name" and then add the missing information
You should then be able to access the Sky Store
