12
This discussion topic has been answered Discussion topic: why does my picture judder on my new 4k led smart television i have tried everything to stop it
This message was authored by: memphis2
why does the picture judder on my new 4k led smart television , i have tried everything to solve it , removed all cables connected into the tv , just leaving the sky q box connected and gone through all the settings menu on the new tv to no avail , everything worked fine with my old plasma tv , i have moved all electical equipment from around it to but still have picture judder, its like robbotic movement
This message was authored by: PandJ2020 Answer
Re: why does my picture judder on my new 4k led smart television i have tried everything to stop it
What source material are you using?  Is it only Q doing it?
(It's most likely TV settings)
It might help if you gave make and model of TV.  Have you tried 1080i and 1080p?  (And 2160p if you have UHD)
Avatar for memphis2
LG 50UR91006LA
Avatar for memphis2
not tried 1080i or 1080p i will have a look at that
Avatar for memphis2
its also doing it through the blue ray to whilst watching a dvd
Then that seems to confirm it's the TV.  (Possibly 'faulty' but more likely motion settings)
Avatar for memphis2
tried all the motion settings still the same , but will try the 1080i ect before contacting the supplier
Avatar for memphis2
don't know how to change to 1080i or 1080 p but will look into it as soon as i can
There is an option in Sky Q around judder.
Home>Settings>Setup>Audio Visual
Select on/off for the Judder reduction option.
It is more around the apps, streaming etc. But, worth a try.
Yeah, the judder reduction only affects apps and puts the display into 60Hz mode rather than 50Hz.
(I'm wondering if it is a native 60Hz panel, causing the judder for 50Hz)
This message was authored by: Craigc1977
what mines does on sky stream,everything works fine until an advert or comes 2 an advert the picture judders and my atmos sound changes audio on the bar,tried everything still same,only wen goes 2 adverts or intervals,any ideas plz
This message was authored by: rowhedge
I was getting picture delay and judder just pulled plug and rebooted
This message was authored by: Invisiblename
Just in case you hadn't noticed, you're responding to a thread that is over a year old
I am just another Sky customer!
