10
Discussion topic: why does my picture judder on my new 4k led smart television i have tried everything to stop it
This message was authored by memphis2 This message was authored by: memphis2
why does the picture judder on my new 4k led smart television , i have tried everything to solve it , removed all cables connected into the tv , just leaving the sky q box connected and gone through all the settings menu on the new tv to no avail , everything worked fine with my old plasma tv , i have moved all electical equipment from around it to but still have picture judder, its like robbotic movement
This message was authored by PandJ2020 This message was authored by: PandJ2020 Answer
Re: why does my picture judder on my new 4k led smart television i have tried everything to stop it
What source material are you using?  Is it only Q doing it?
(It's most likely TV settings)
It might help if you gave make and model of TV.  Have you tried 1080i and 1080p?  (And 2160p if you have UHD)
I am just another Sky customer and my views are my own
memphis2
LG 50UR91006LA
memphis2
not tried 1080i or 1080p i will have a look at that
memphis2
its also doing it through the blue ray to whilst watching a dvd
Then that seems to confirm it's the TV.  (Possibly 'faulty' but more likely motion settings)
memphis2
tried all the motion settings still the same , but will try the 1080i ect before contacting the supplier
memphis2
don't know how to change to 1080i or 1080 p but will look into it as soon as i can
This message was authored by lettice This message was authored by: lettice
There is an option in Sky Q around judder.
Home>Settings>Setup>Audio Visual
Select on/off for the Judder reduction option.
It is more around the apps, streaming etc. But, worth a try.
Yeah, the judder reduction only affects apps and puts the display into 60Hz mode rather than 50Hz.
(I'm wondering if it is a native 60Hz panel, causing the judder for 50Hz)
This message was authored by Craigc1977 This message was authored by: Craigc1977
what mines does on sky stream,everything works fine until an advert or comes 2 an advert the picture judders and my atmos sound changes audio on the bar,tried everything still same,only wen goes 2 adverts or intervals,any ideas plz
