Discussion topic: upgrade from sky SD to skyQ
Message posted on 23 Feb 2024 01:23 AM
Re: sky plus LNB and dish
@mgrover75 wrote:
hi to all
i have sky plus so does sky q use the same LNB and DISH
@mgrover75 Sky Q uses the same dish but the LNB needs to be changed to a wideband LNB the engineer should check the dish and cabling to make sure they are still in good condition
Message posted on 23 Feb 2024 06:42 AM - last edited: 23 Feb 2024 06:47 AM
@Laing1 wrote:
@mgrover75 wrote:
hi to all
@mgrover75 But as per our previous replies - if your dish is not suitable (due to a different LNB collar or any other reason) it will also be replaced
This also mentioned in the notes I linked to in post #4 - if you haven;t read them I do suggest you read them as they cover many points that people upgrading may wish / need to know
Are you concerned over such a replacement ?
