Discussion topic: technical fault message
Message posted on 29 Aug 2023 06:57 PM
every time I switch on the tv and choose a channel I get a "techincal fault" message when trying to use the menu there is quite a delay also get message saying I am not connected to my wifi, when I check my router and sky settings they are ok. 've turned off sky and then back on to reset but still have the same problems
Message posted on 29 Aug 2023 07:03 PM
Re: technical fault message
@Chris5004 As Sky Q doesn;t rely on wifi for live channels is this a Glass/Stream setup you have?
Message posted on 29 Aug 2023 07:07 PM
It's regular Sky Q
Message posted on 30 Aug 2023 07:52 AM
This is what has been happening to me. I think it's a glitch their end. Has yours resolved?
Message posted on 30 Aug 2023 09:05 AM
Hi @Chris5004 do you have Glass/Stream, try, rebooting your router by removing the power cable for 30 sec then reconnect, then reboot your SKY hardware?
Message posted on 30 Aug 2023 11:33 AM
Think he has said above, regular Sky Q.
Message posted on 30 Aug 2023 11:51 AM
Thank you all for your assistance, unfortunately Having spent over 2 hrs on the phone with sky being walked through fault finding, re-setting etc. I've had to have an engineer call out as it appears it may be my SKY Q box !! (not due till Wednesday .....)
THANKS
Message posted on 14 Sep 2023 10:07 AM
All sorted, apparently it was a faulty sky q box, swapped and now working fine
Thankyou all
