Discussion topic: sky q
This message was authored by: gunners1951
sky q
box keeps changeing remotely
Re: sky q
@gunners1951
Avatar for gunners1951
Re: sky q
it is an old box and needs up dating
Re: sky q
Then update it @gunners1951
Make sure it is on the latest software.
https://www.sky.com/help/articles/updating-sky-box-software-sky-q
Re: sky q
it is an old box and needs updating
Re: sky q
@gunners1951
So you've already said… and received a reply.
