Discussion topic: Recordings not loading on sky q mini
This message was authored by: Lmb2712
All recordings are just saying please wait My sky q mini box says everything connected on the app and no known issues but cannot load any recordings
Re: Recordings not loading on sky q mini
Hi @Lmb2712
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
