Discussion topic: sky q mini box no channels
Message posted on 03 Aug 2024 04:44 PM
My Sky Q mini box is giving me the message 'Please check your subscription entitles you to view this channel on this box etc.' I recently cancelled TNT sports and this has now happened. The main box is fine, just the mini box has the issue. I have reset both boxes numerous times and this has not helped.
Message posted on 03 Aug 2024 04:56 PM
Re: sky q mini box no channels
Hi @spenny108
First try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Failing this try a Reset Settings in the Q box hidden menu.
Message posted on 03 Aug 2024 05:07 PM
@oldfella Hi, tried that a couple of times now, everything says it's connected, main box is all good, but mini box getting nothing
Message posted on 03 Aug 2024 05:39 PM
Hi @spenny108
l looks like Sky may have messed up your account when you cancelled TNT.
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
Message posted on 03 Aug 2024 06:00 PM
Thanks for escalating. We've sent an invite to @spenny108.
Tom
