Discussion topic: Wi Fi freezing
Message posted on 03 Aug 2024 05:25 PM
Wi Fi freezing
My mini box keeps freezing all the time
main Q box is fine
Message posted on 03 Aug 2024 05:59 PM
Re: Wi Fi freezing
main Q box is fine
@WILLIAMDAVIES Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 03 Aug 2024 06:11 PM
Re: Wi Fi freezing
main Q box is fine
If the reboot doesn't help try a Network Reset on the mini.
