Discussion topic: sky q box intermittent signal loss
This message was authored by DAVID6000 This message was authored by: DAVID6000
I have had sky q for several months without any problems. I noticed earlier today after watching some pre recorded programmes that there was no signal on the sky q box. I turned everything off, then turned  everything back on and the signal duly returned.
Unfortunately the same issue has arisen on a further two occasions. Each time the standby light was on green so there was no obvious indication that anything was wrong and it was only when I switched from watching pre recorded tv to live tv that I discovered the signal loss.
I checked my account on sky tv which stated that my box was fine and I also checked on settings which currently tells me that I have a good signal and that the satellite signal is locked and the signal strength is 80 and the signal quality is 90. I had recorded a programme that was on for about 5 hours but has only recorded the first 1 hr 45 mins so you can see that this is frustrating.
One final point,  I have had some renovation work done in my flat, so I did not watch tv for a week and I  unhooked the two sky dish cables from the back of the tv. I put them back in on Friday and if this issue had started then then I would assume I had not put the cables back in correctly but the box worked perfectly on Friday, Saturday, Sunday and until Monday afternoon.
Any help would be appreciated.
David
Re: sky q box intermittent signal loss
Hi @DAVID6000
Could possibly be a poor connection on the cables or a slight dish misalignment .
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
DAVID6000
Hi @oldfella
Thanks for the info.
I hope it is not a dish misalignment as prior to getting Q i had sky+ and when the engineer came to change to sky q he told me that the dish was misalighned which was why I was losing channels to no signal on a daily basis.
I will leave it for a day or so and take the dish cables out and put them back in and see if ithat does the trick.
This message was authored by Chodley This message was authored by: Chodley
There aren't trees in the line of sight to the satellite are there?
