Discussion topic: recordings not showing
This message was authored by: Paul-Round
I have series link for our local news, but it never shows up in my recordings even though you can see the recording icon when it's on.
Re: recordings not showing
hi @Paul-Round
If you have a series link set for any program then you need to look in Recordings - Scheduled to see exactly what is set to record.
Avatar for Paul-Round
Level 3 icon
This is the odd thing, it shows up in scheduled, but never knows up as recorded.
Update, I found them, I also found some other stuff that I couldn't find. It appears the Q box doesn't differentiate between national news and local news, which is damned annoying.
I also had the same issue with some recordings from the chinese grand prix, it bundled the grand prix and chequered flag under qualifying.
Is there any way to change this behaviour or is it 'a feature'?
