Discussion topic: no signal
This message was authored by: Annabelle4
no signal
Skybox can't get signal
Avatar for Annabelle4
Re: no signal
Sky Q box cannot get signal
Re: no signal
@Annabelle4
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
