Discussion topic: UHD not activating
This message was authored by: kyledeca
UHD not activating
Recently renewed my Sky package after having a 24 hour break 😂
UHD has since failed to reactivate on my box. Have contacted live chat twice, both promising it will come back on firstly within 4 hours and then within 2 hours.
getting a MySky_1802 error message saying I'm already subscribed but it doesn't work - very frustrating.
anyone else come across this and any suggestions to fix? Have tried the callback on viewing card and restarting Sky q box.
Re: UHD not activating
Hi @kyledeca
Avatar for kyledeca
Hi @oldfella
Thanks for the suggestion. It didn't resolve the issue unfortunately. I did some searching and looks like a couple others on this forum have had the same issue im experiencing.
although, the message has changed now stating I need to upgrade my subscription, rather than it telling me I'm already subscribed.
maybe it'll now sort itself out by the morning but I'm not hopeful and looks like I'll be contacting Sky again in the morning to try and sort it out.
Avatar for kyledeca
Had a sky engineer turn up on Saturday. Explained the issue to him - he just rolled his eyes. He knew there was nothing he could do from my home. He replaced the UHD box and went through the motions as he would be required to do these steps before being able to raise it any further. he told me that he would raise a CRF or something along those lines and explaining this what the issue is and that would likely be a "back end" issue.
I haven't heard anything from that but have also been in touch with Sky via X (twitter) who have also escalated this issue but I'm not able to provide me with any information except that they can see that it hasn't been looked at yet.
finding this very frustrating to be honest with the lack of information as to what the issue is or what this issue could be.
to top it off they charged me for the sky engineer visit, despite him not being able to fix the issue. Needless to say I have been in touch with regards to that and it has been now removed from my bill.
