Discussion topic: multi screen
This message was authored by: Daniel0410
multi screen
i wish to have multi screen added to my account
Re: multi screen
@Daniel0410
Contact Sky to have it added as well as any mini boxes you may wish to order.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: multi screen
Hi @Daniel0410   To do that have a look at your offers on your Sky Q box, MySky App or website. For the best deals telephone Sky. If this is for another TV, remember to request a Mini box at the same time.
