Discussion topic: TNT sports channels not working but all other channels are
Message posted on 21 Nov 2025 09:37 AM
TNT SPORTS not working, message says this channel is currently affected by a problem with your satellite signal, but all of the sky channels are working fine. It’s just the TNT sports that are not working.
Message posted on 21 Nov 2025 10:05 AM
Re: TNT sports channels not working but all other channels are
@Dabbo_Real
If you are seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
