Discussion topic: green light will not come on
This message was authored by: nimba777831321
green light will not come on it stays at amber i hve tried switch off  took all the cables from the q box left for at least 10 mins done this for several times but no luck so far is there anything else i could try
Re: green light will not come on
Hi @nimba777831321
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
