Discussion topic: connection issue
This message was authored by Wardo This message was authored by: Wardo
connection issue
I have just installed a new 55" Samsung wall mounted TV and moved my mini sky box from the multi room package from an upstairs bedroom into my converted conservatory and the TV is saying there is no signal or Internet connection.
The box was working perfectly in the bedroom.
I have gone on to the main TV and says everything is connected, but the new TV won't connect.
Can you assist
regards
David.
Re: connection issue
Can you assist
regards
David.
Hi @Wardo
When you say the New TV won't connect do you mean the mini box or the TV?  (Bearing in mind that the TV set will also have the capability of connecting to your internet)
If you mean the mini try the following.
Reboot the mini as above.
