3
This discussion topic has been answered Discussion topic: Sky
This message was authored by: Barbiport
Sky
Hi have sky Q T2? need to buy new tv will I be able to just reconnect the cables from my new tv to my sky Q box? I am a techno phobe so am hoping it's easy, will I need to register the new tv make on my sky Q remote also?
Re: Sky
Hi @Barbiport
Should not be any difficulty and as you suggest you just connect the Q box HDMI lead to your new TV..
Unless it is the same brand you will have to re pair the remote to new TV to control TV volume and power on/off.
You can completely reset  your Bluetooth remote.
Re: Sky
Hi @Barbiport
Avatar for Barbiport
Level 2 icon
Re: Sky
Thank you @oldfella ill give it a go, yes it will be another Samsung but an LED instead of my old faithful LCD! 👍
Re: Sky
Hi @Barbiport
You may be lucky and find that the remote works with the new TV.
If it doesn't it's a very simple pairing procedure.
Any issues post back here.
