Discussion topic: New box
This message was authored by: DarrylA11
New box
I need a new mini box
Re: New box
@DarrylA11
Perhaps if you tell us what's wrong with the mini box you've got?
Avatar for DarrylA11
Re: New box
Just want new box as other will not link
Re: New box
@DarrylA11
What have you tried already?
Re: New box
Hi @DarrylA11
Assume this is your Main Q box not a Q mini.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
