Discussion topic: You tube buffering
This message was authored by Jenny77 This message was authored by: Jenny77
You tube buffering
This past week the youtube app has been intermittently buffering where it never has done so before. We have no Internet issues. My young son is Autistic and really struggles every time it comes up loading on the screen- please help!!!
This message was authored by cuke This message was authored by: cuke
Re: You tube buffering
Does the tv also have a youtube app? If so try that and report back...
Jenny77
No sadly not.
This message was authored by SeanW72 This message was authored by: SeanW72
I'm experiencing something like this. The video stream and a audio suddenly goes out of sync and then the video pauses and we get the buffering sign where it gets stuck. If you skip the video forward using the remote it suddenly jumps back a few seconds and starts playing again. No internet issues, so anyone got any ideas.
This message was authored by Chodley This message was authored by: Chodley
Hardwire your Q to the router
This message was authored by dhield This message was authored by: dhield
My SkyQ has also developed this unusual buffering symptom after pausing a YouTube video then resuming. Goes out if sync then buffers. Never did this before. My sky q is hardwired and I get 500mbps download speed.
Is wifi disabled?
Yes, I have disabled WiFi on all SkyQ devices. But is there an easy way to check that Sky Q hasn't defaulted back to WiFi and is using the hardwired cable connection?
This message was authored by martin261170 This message was authored by: martin261170
Ive been getting the same. never happened before. Same videos are working fine in the TV's app so its not the internet signal. Wifi is off too and everything hard wired back to the sky q main box. Contstantly getting tv schedule not found as well.
Yeah, double check it's still disabled.
This message was authored by biscuitdog2020 This message was authored by: biscuitdog2020
I'm having a similar issue if I pause it it suddenly jumps back and freezes I'm guessing if is the app as it's only done it in the last few weeks
Also I'm hardwired not WiFi
This message was authored by Vegeta This message was authored by: Vegeta
After putting up with this the past month or so, I thought I would check to see if it was just my homes Sky that was having this issue on YouTube when you pause. It was never an issue for years previously, and looking at the comments it looks like everyone has the same issue, so I'm assuming it's something Sky have changed.
I really hope they fix it, as it's very frustrating.
There has been no change with this for me. Its really annoying because even a breif pause causes the buffering. So long as you dont hit pause, its absoutely fine but that's not really good enough.
This message was authored by jjclaws This message was authored by: jjclaws
Exact same issue as described by many others. Pause playback momentarily and then press play to continue playback. Video will initially play then will run briefly with no audio before eventually pausing. Eventually the video will restart normal playback. It appears it can be sped up by fast forwarding the video slightly. Again, like others this issue has only started in the last couple of months. Quite frustrating and would be nice if an update was put in place to resolve.
This message was authored by Swiney This message was authored by: Swiney
Exact same issue here. Does anybody know a fix as of yet?
