7
This discussion topic has been answered Discussion topic: Sudden loss of channel!
This message was authored by: SS2025
Hi all very new to SKY just joined
The channel I was happily watching suddenly turned off, spent the last 25 mins following instructions without success, so annoying. The backlight on my remote is pulsing, what does that mean?
Surley, can't be the batteries?
I've just started using ( just over a wk)
This message was authored by: nigea99 Answer
Re: Sudden loss of channel!
It is quite likely due to the weather - please see:
Snow affecting Signal
This message was authored by: Buzby321
Mine went down also, been with sky 12 years now, not sure what's going on!
Avatar for SS2025
Was fine yesterday morning just not 02:00 switched off !!! Frustrating ! Maybe it's tell me switch off and Zzzz:)
Avatar for SS2025
Thank you much appreciated!
it's done it again just now  07/01/25 02:00am
Time to try and Zzzz 🙂
@SS2025 If you box is switching off at 2.00am then you may have the standby settings set to eco try canging them on the main box and any mini boxes you may have to active or none
see below for an overview of the settings
https://www.sky.com/help/home/sky-tv/sky-tv-q/using-sky-q/settings-and-preferences-q-test/standby-se...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Eco Mode only kicks in at 02:45.
Maybe it wasn't exactly 2am when it happened
to be fair, unless you're working shifts, that ain't a healthy time to be awake anyway 😁
