Discussion topic: Sky Q without broadband
This message was authored by: middlesex1993
I suspect other threads have discussed this topic.
I have a Sky Q box connected to my smart television.
I have Bt broadband and my current BT smart hub 2 router is not working so I currently have no broadband until
i get a new BT router.
I can still watch live tv on my television via my Sky Q box and record programmes..
I can not get anything else including catch up television and Apps. When I click on Catch Up or Apps, a message comes up saying I am not connected to broadband etc.
Is the above all correct.
Thank goodness I do not have one of the new Sky Streaming boxes Then I would be in real trouble.
This message was authored by: Sparkymatt100
Re: Sky Q without broadband
Yes thats all correct.
Live TV on Sky Q is by satelite feed so would not be affected by broadband issues, whereas as you have found, catchup, on demand and apps (Netflix, Prime, Disney et al) are streamed through your broadband, so these would not work until you get your new router.
As you have guessed (removed) if you had Sky Stream puck or Glass as this does indeed stream via broadband and wont work without it.
Moderator note: Removed inappropriate language
LG OLED65C3" 4K HDR TV
Sky Q 2Tb HDR
Mini Box
Sky Full Fibre 300
As you have surmised, all those services run over broadband, they can't work over the one way satellite transmission.
I always keep a spare router in a cupboard in case mine fails one day. Only had it happen once in 20 years though 🙂
Avatar for middlesex1993
Level 8 icon
Sparkymatt100
I got an email saying you had replied to my thread but it did not appear.on this thread.
Chodley
I assume you are saying that I am correct.
I can  only watch live channels and record programmes. Nothing more until I get a new  BT smart hub 2 router,
By the way. On average how many years do these BT  routers usually last.
My BT Smart Hub lasted 5 years, before it was replaced in the latter months of last year. It was still working even then, but had an intermittent fault and failed BT's health test.
