Discussion topic: Won’t record a program!
This message was authored by: James1968
Trying to record sky's arenaHD Blackburn V Coventry and it won't, I keep getting the message "This programme cannot be recorded " why?
Re: Won’t record a program!
Hi @James1968
Try rebooting your Q box.
@James1968
I've just tried to set this to record on my box and getting the same message so it may be something Sky's end. Not sure if it would be in time but you could email the Viewer Relations Team at viewerR@sky.uk
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
This message was authored by: Doc5907
@James1968  have also tried to record this and getting same message as you. Might be worth sending an email to Sky Viewer relations at:
ViewerR@sky.uk
They do respond to emails with any updates and pass onto the relevant Sky teams.
Also worth trying later in the day as they sometimes fix it over the course of the day.
Sky Q 1TB UHD
LG TV
Sky Mobile
@James1968
This match has now allowed me to set it to record.
