Discussion topic: Wireless TV?
Message posted on 02 May 2023 05:02 PM
Wireless TV?
Hello. I am remodelling my living room and the tv and sky box will be moved to a location which is virtually impossible to reach with the leads from my satellite. Is there a way I can connect wirelessly to the satellite with my existing box? Some kind of receiver?
Message posted on 02 May 2023 05:06 PM - last edited: 02 May 2023 05:06 PM
Re: Wireless TV?
Sorry @Will+Roberts SKY Q must be connected via cables.
You could consider switching to SKy Stream but it is quite different streaming everything, and no hard disk to record on etc
Message posted on 02 May 2023 05:06 PM - last edited: 02 May 2023 05:07 PM
Re: Wireless TV?
Not practically @Will+Roberts .
One option would be to use a Sky Q mini box at your living room TV.
You may need to occasionally connect a TV to your main Q box.
Bear in mind that the mini will not do UHD
Re: Wireless TV?
@Will+Roberts afraid not the box does need to be connected to the leads from the dish
Message posted on 02 May 2023 05:10 PM
Re: Wireless TV?
You mean connect your Sky Q box wirelessly to the satellite dish? There's no way to do that, I'm afraid.
You could, I suppose, leave your Sky Q box where it is, and obtain a Mini box which connects wirelessly to your Sky Q box, though you'd lose UHD capability.
Or Sky Stream which doesn't require a dish connection might be an option.
Message posted on 02 May 2023 05:31 PM
Re: Wireless TV?
@Will+RobertsYou will either have to pay to have your leads from the satellite moved or buy an satelite extension lead kit.
