Discussion topic: Access TV with Sky Q Remote
Message posted on ‎02 May 2023 05:19 PM
Hello there. How do I access the features on the smart TV with the sky q remote without having to use x 2 remote controls? I have paired the sky q remote in settings, but how do I now access the web features of the TV? Eg, pairing bluetooth headphones? There is nothing in the sky q box settings. Would like to escape having to live with x 2 remotes! Thank you.
Message posted on ‎02 May 2023 05:24 PM
Re: Access TV with Sky Q Remote
Hi @Rogostar The only things that a Sky Q remote can control on your TV are volume, power and select input. Nothing else.
Message posted on ‎02 May 2023 05:26 PM
@RogostarUnfortunately the Sky controller will only control on/off and volume on your TV.
Message posted on ‎02 May 2023 05:26 PM - last edited: ‎02 May 2023 05:27 PM
@Rogostar afraid you cannot all the Q remote will control on your TV is the sound volume and on/off and on some TV's the source
Message posted on ‎02 May 2023 05:41 PM
Hello, minor progress update. Ysing the TV remote, I have paired (after going through a million settings) the headphones. Thought for a moment I'd have to do that every time. Switching hphones reverts TV to normal speaker although it takes about 35 secs. But then I have to use the TV remote, access dashboard, re-select HDMI1 (sky q box). I am not finding any of this very smart!!! Help please 😢😢
Message posted on ‎02 May 2023 05:43 PM
So I am still essentially stuck with two remotes? Cleafly tge TV remote won't control the sky box? Thanks
Message posted on ‎02 May 2023 05:44 PM
Thanks, can you clarify the 'source'?
Message posted on ‎02 May 2023 05:51 PM
Message posted on ‎02 May 2023 05:52 PM
Not so fast. If I want to use the headphones, I have to use the TV remote, go into all the sound settings and re-pair them EVERY SINGLE TIME 😢😢😢 Only reason we got the TV was my partner was fed up with the old wired headphone cable. You know, the one you plug in & it works instantly!!!!
