3
This discussion topic has been answered Discussion topic: Why does Sky comedy not come in standard definition?
This message was authored by: Creature0fhabit
I have recently downgraded my HD package and as a result can't watch the one programme on Sky comedy I watch, Last Week tonight.
All other channels in the entertainer package have a non-HD option why not Sky comedy??
This message was authored by: nigea99 Answer
Re: Why does Sky comedy not come in standard definition?
hi @Creature0fhabit
SKy Comedy is available in SD - try channel 814 if the listing on 114 is still HD
If it is a download then :
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Edit : Note you can't watch any HD versions you may have downloaded  or recorded when you had the HD sub
Hi @Creature0fhabit   I would be surprised if your fellow customers would know why. You could try viewer relations by emailing [email protected]
hi @Creature0fhabit
Avatar for Creature0fhabit
Level 2 icon
Thanks the download tip was useful as was the 114 channel. I scrolled through and couldn't find it.
