Discussion topic: What my sky in static caravan
Message posted on 12 Aug 2024 10:50 AM
Message posted on 12 Aug 2024 12:18 PM
Re: What my sky in static caravan
@Toonman66 wrote:
Hi all, I currently have sky q and have also 2 multi room boxes. I am getting a static caravan in Northumberland and would like to watch sky and netflix etc the site has no WiFi and would charge 800 for broadband. I have checkvthe area and only EE has 4g 5g in place the other networks do not. I am with o2 and get no or little service in the caravan what do I need to do to watch my sky.
@Toonman66 If the Static has its own address then Sky would be able to install Sky Q for you and give you an account for your static.
To make full use of the Q box and to watch netflix or if you were thinking about Sky stream you would need broadband of some description as well, whether this is by one of the major broadband providers or by way of 4G/5G.
If you are not getting a reliable signal then Sky Stream won't work, Netfix will possibly work if you can get a signal but may be flakey/buffering and Sky Q you would not be able to use catchup or the red button services
