Discussion topic: Q Box
Message posted on 12 Aug 2024 01:06 PM
Q Box
My Sky Q Box is not working, have tried rebooting it under settings > status, still not working
the main Sky box is fine !!!!
Message posted on 12 Aug 2024 01:19 PM
Re: Q Box
There is no reboot in Settings Status.
Reboot the mini as above.
