Discussion topic: We have changed WiFi provider but our sky Q boxes won’t work now
This message was authored by PE4 This message was authored by: PE4
We have changed our internet provider but our sky W boxes won't work today
This message was authored by lettice This message was authored by: lettice
Re: We have changed WiFi provider but our sky Q boxes won’t work now
On each Sky Q box go  to your settings > network and perform a network reset, then follow the prompts.
Hi @PE4
Try to get your main Q box connected first.
Start with a  reset your broadband router.
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
