Discussion topic: Lost schedule recordings
Message posted on 16 Aug 2024 03:11 PM
Have googled this and it says press services on handset to start rebuild. There is no service button on my sky q handset. Have lost all series link future recordings. Have tried reboot but that's doesn't work.
Message posted on 16 Aug 2024 03:16 PM
Re: Lost schedule recordings
Try rebooting your router first, then reboot your Sky Q box and then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Message posted on 16 Aug 2024 03:36 PM
Hi Daniel. Have tried that with no success. This keeps happening so maybe we need sky engineer out. Thank you for your reply.
Message posted on 16 Aug 2024 03:42 PM
Hi @Tommox2
There is no Rebuild on Sky Q.
Rebuild in Services is only on Sky+.
You could try a Reset Settings in the Q box hidden menu.
Message posted on 16 Aug 2024 03:52 PM
Think this is beyond my capabilities unfortunately. Thank you very much for trying to help me.
