Discussion topic: Watching live F1
Message posted on 07 Dec 2024 12:04 PM
Watching live F1
I have upgraded my account so that I have the f1 channel but it continually tell me to upgrad. I can only watch f1 live on my phone on the sky go app
Message posted on 07 Dec 2024 01:26 PM
Re: Watching live F1
On what device as you seeing this upgrade message ?
Message posted on 07 Dec 2024 03:47 PM
I'm trying to watch on my sky Q box.
Message posted on 07 Dec 2024 04:29 PM
I have moved this to the Sky Q forum for you.
Message posted on 07 Dec 2024 04:34 PM
hi @shanerg
There are is a UHD version of the channel as well as the HD version.
If you don't have the UHD add on it will prompt you to upgrade if you try to watch - the system should 'smart' switch to move the UHD further down the channel list if you don;t have the UHD add on but sometimes it doesn't work or takes time to sort itself out
Could this be your problem ?
Message posted on 07 Dec 2024 06:20 PM
I didnt know about this I'll have to give it a look at.
I was going on
sport menu- F1-live
So was unaware of the uhd and Hd channels
Message posted on 07 Dec 2024 06:31 PM
I was going on
sport menu- F1-live
@shanerg try channel 406 to start with
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 07 Dec 2024 06:37 PM
Message posted on 07 Dec 2024 06:45 PM
No i haven't noticed anything other than upgrade to use
Message posted on 07 Dec 2024 08:03 PM
@shanerg wrote:No i haven't noticed anything other than upgrade to use
@shanerg goto Home>>>Tv guide >>>sport
And scroll down clicking on every channel that says SkySpF1 until one works for you.
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 08 Dec 2024 01:23 PM
I've had exactly the same issue- Ch406 says I have to upgrade- which I have. I have started watching on Sky Go (I pad) but saw F1 Abu Dhabi live, HD (not UHD) on Ch357???
the Red button seems to cause all sorts of problems.
Also - there is a massive time shift between Sky Tv & Sky Go???
Message posted on 08 Dec 2024 01:37 PM
@JohnTf22 wrote:Also - there is a massive time shift between Sky Tv & Sky Go???
Yes.
