Discussion topic: Watch sky without a satellite
This message was authored by: Sarafry
can you watch sky without the use of a satellite dish
Re: Watch sky without a satellite
Sky Stream, which provides Sky via the internet may be an option, depending on your broadband speed.
@Sarafry  Yes by subscribing to either sky glass or stream, note broadband connection required
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
As others have mentioned, you can indeed watch Sky TV without a dish using Sky Stream or Sky Glass with your broadband connection. You can also watch it via the NOW TV app which gives you access to all the main Sky channels live and access to the on demand catalogue of content. It can work out cheaper using this if you don't want or need any of the additional free-to-air channels which Stream and Glass provide. Various options are available, depending on how you watch TV and how much of it you want access to on your budget.
