Discussion topic: Connection to sky q box
This message was authored by: Kay106
So I got no connection to my mini box  coming up with
there is a network problem
Re: Connection to sky q box
@Kay106 Have you tried rebooting your main Q box ie
then
reboot your mini box
Hi @Kay106
Try a Network Reset on the mini.
