Discussion topic: WPS light not working
Message posted on 18 Mar 2023 08:19 PM
When I press and hold the WPS light on my sky router nothing happens. No light at all. I cannot reconnect my router to my Sky Q box.
Message posted on 18 Mar 2023 08:22 PM
Re: WPS light not working
Hi @Ed+Davidson
As far as I am aware the WPS button on the router is on the right hand end near the bottom..
Make sure that you are not pressing the router reset button
Message posted on 18 Mar 2023 08:24 PM
Thanks. Definitely pressing the WPS button.
Message posted on 18 Mar 2023 08:28 PM
Try resetting the router then @Ed+Davidson
