Discussion topic: Sky q green
This message was authored by: PNM10
Sky q green
Hi, my sky q box has just suddenly started producing a green screen. No sound. I have tried various high quality HDMI cables. I have disconnected from my amplifier and gone straight to the tv and has the same result. I have tried to reset the box and the sky welcome message comes on and then the same problem happens. Can anyone help. I have been loyal to sky for 23 years.
Re: Sky q green
Hi @PNM10
With Settings highlighted 0 0 1 Select.
Re: Sky q green
@PNM10  It would be helpful to engage in this thread that you created rather than creating multiple threads for the same issue.  Spamming the forum in this way isn't the best idea.
