Discussion topic: Volume problems
This message was authored by Jimdag This message was authored by: Jimdag
Volume problems
My main sky q box tv volume goes down by itself to 0, sky q mini box TV volume goes up by itself to 100
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Volume problems
The Q boxes themselves have no concept of volume.
The remote contol can be programmed to provide volume up/down signals - ensure buttons are not stuck on the remote?
I am just another Sky customer and my views are my own
Jimdag
Re: Volume problems
Thanks for your help but something is altering the volume & as the sky boxes are the only thing that connects both tv's I thought it might be sky q boxes.
This message was authored by cuke This message was authored by: cuke
Re: Volume problems
Surely it is the tv own volume control not the sky boxes?
Re: Volume problems
hi @Jimdag
As @PandJ2020 says the boxes themeselves do not have any volume control so check that the remotes do not have buttons sticking.
Also check that something is not pressing on the TV's own remotes
Jimdag
Re: Volume problems
Its not the remotes as i can go into the tv menu click on another item then turn up the volume & it stays where i put it, but then come out of menu & the volume goes down again, Baffling.
Thanks for your help anyway
Re: Volume problems
Volume commands can also be sent over CEC - anything connected via HDMI?
