Discussion topic: Sky Cinema and Q Mini Box
This message was authored by Mattyc99 This message was authored by: Mattyc99
Hi,
We have a Sky Q 2tb UHD box as our "main" hub as such in the lounge and 3 Q Mini boxes around the house.
Is Sky Cinema available in UHD to the Mini Boxes? Potentially could be a deal breaker if not....
Re: Sky Cinema and Q Mini Box
@Mattyc99 wrote:
Hi,
hi @Mattyc99
Afraid minis will not do UHD.
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot view UHD recordings or content.
No: Q Mini boxes (which essentially have a specification from 2016) are not equipped with 4K video chipsets and so cannot output UHD from any source.
To have multiple Sky television devices outputting UHD you'd need Sky Stream.
This message was authored by PandJ2020 This message was authored by: PandJ2020
...and sufficient internet bandwidth to drive them...
