10
This discussion topic has been answered Discussion topic: Volume down to zero on its own.
This message was authored by: Jd19900927
When I turn my sky q mini on the volume automatically drops to zero. Then when I increase the volume it goes up steadily as if trying to drop down. As soon as I let go of the volume up button it drops back to zero again. What can I do to fix this?
Re: Volume down to zero on its own.
@Jd19900927 wrote:
Yes it did. It drops to zero and keeps trying to drop further sometimes. Other times it stays at a constant volume for a few minutes then drops.
Maybe worth a reboot of the TV @Jd19900927
Or a Factory reset.
Hi @Jd19900927
Check that the Volume control button on the mini remote is not sticking
Avatar for Jd19900927
It doesn't seem to be sticking, button seems fine.
Hi @Jd19900927
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
@oldfella wrote:
Hi @Jd19900927
in addition to this can I suggest that after resetting the remote (the 7 &9 step) & before pressing the 1 & 3 to re-pair you try using the TV's own remote to check that there is not a fault with the TV itself
Carried out resets and with batteries out on both remotes the volume still drops to zero.
did it reset to zero whilst the SKY Remote was not paired ?
In which case it sounds like a fault with the TV
Any chance something has got into the volume button the TV itself (not the remote) ?
Or a Factory reset.
Fingers crossed a factory reset of the tv seems to have worked, thanks for your help everyone.
