Discussion topic: Fault sky box
This message was authored by: Justy8sl
Fault sky box
My main sky Q box is faulty, it keeps cutting out. We have changed the HDMI cable and used a different port in the tv. Can it be replaced?
This message was authored by: Ecosse
Re: Fault sky box
A couple of things, initially the trusty reboot:
I'd suggest fully rebooting the Sky Q main box.
Unplug from the wall for at least 30 seconds.
Now plug back in the Sky Q box and follow the on-screen instructions. This can take up to 5 minutes, and hopefully, you're back up and running.
Then, contact Sky as the boxes are leased, go to this link: https://www.sky.com/help/home
Scroll to the very bottom of the page and now select the Need More Help dropdown, this will lead to a phone contact.
Ignore the automated messages, just wait for an advisor
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Re: Fault sky box
As mentioned above.
Try a power reset of your Sky Q box and also your TV.
For the TV take out all the hdmi leads, leave off power for a few minutes.
Once TV is back up, put the hdmi lead/s back in.
Then power up the Sky Q box
If this still does not solve the problem, come back here and we can get it escalated to Sky for you.
No need to call Sky, we  will ask Sky  online escalation to work with you for a Sky box replacement and/or engineer.
Avatar for Justy8sl
Re: Fault sky box
The issue with my sky Q box has not been resolved by following the instructions on rebooting that were sent, it is still cutting out
Re: Fault sky box
Time to call Sky if you suspect a faulty box...
Re: Fault sky box
What exactly does "cutting out" mean? Wondering if this is the "small box jumping around the screen" thing.
