Discussion topic: Voice control
This message was authored by: PaulK32
Voice control
How can set up voice control as when I press the remote it keeps saying I didn't hear that
Re: Voice control
@PaulK32
There is no setting up. Just press and hold the voice button and say clearly your command ie; "go to 25 minutes".
Re: Voice control
If Voice control is not working on your Sky Q, you may need to re pair your remote.
Press and hold 1 and 3 together on your remote to begin the connection process.
Once complete, press and hold the
Voice Control button, to confirm that Voice Control is now working.
More info here;
https://www.sky.com/help/articles/using-voice-control-on-your-sky-q-box
This message was authored by: ozsat
Re: Voice control
Background noise can also get in the way of it hearing. A loud tv or someone else speaking.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Re: Voice control
HI @PaulK32
It is, also, worthwhile checking that nothing is blocking the small microphone hole - on the latest handsets it is between the SKY Logo button and the Play/pause button.
Perhaps try cleaning it with toothbrush or similar or even carefully with a small pin
Avatar for PaulK32
Re: Voice control
Thank you it worked perfectly
