Discussion topic: Downgrade
This message was authored by: Gary226
Downgrade
Hi, want to downgrade or even cancel
Avatar for Gary226
Level 0 icon
Re: Downgrade
Downgrading or cancel
Re: Downgrade
@Gary226
To cancel your TV subscription fully, if you’re out of contract you’ll need to give Sky the required 31 days notice. The latest T’s and C’s explicitly state you can’t cancel when still in a minimum term deal unless Sky agree. If they agree you’ll have to pay the remainder of your discounted term.
Select ‘Need more help’ at the bottom of the following link which will lead to contact details.
https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ The link may include an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ it’s only by calling Sky Ireland or writing in.
If you successfully cancel you should receive an acknowledgment email from Sky.
If you are cancelling Sky Q, return packaging will be sent out near the end of your notice period. It’s important that you obtain proof of posting and keep it safe and indefinitely.
To remove part of your TV package you need to give Sky 31 days notice. Be aware if you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount. You may be able to remove it from your MySky account at
https://www.sky.com/mysky/tv/tv-packs
otherwise you can either call Sky or maybe try the messaging service
