Discussion topic: Viewing card
This message was authored by: Nicky5
Viewing card
We have a new sky Q box but have not been sent a viewing card.
Re: Viewing card
You use the one you ejected from your old box before returning it.
Avatar for Nicky5
Level 0 icon
Re: Viewing card
We don't have an old sky tv box we are a new customer
Re: Viewing card
Ok, the installing engineer should have one with them when they mount your dish.
Re: Viewing card
@Nicky5
The viewing card is normally posted out to be received before the engineer arrives with the Sky Q box. The engineer normally carries spares. How did the engineer show you how the box worked?
Re: Viewing card
Hi @Nicky5
Are you sure it's a Q TV box you have received?
Normally only the Broadband hub is posted out and all TV boxes are carried by the installer.
