3
This discussion topic has been answered Discussion topic: Viewing card popping out
This message was authored by: Claire14
We reset the box after moving it and every day the viewing card pops out and is asks to be reinserted. Tried resetting again and no luck. Do I need a new viewing card?
This message was authored by: PandJ2020 Answer
Re: Viewing card popping out
@Claire14 wrote:
Thanks but it takes a really firm push to get it back in so I doubt tape would hold it!
Ok, you'll need to call Sky as it seems the slot isn't working correctly.  Only a reasonable push should be required assuming the card isn't damaged.
Remember to remove the card when swapping the box and unfortunately you'll lose all your recordings.
If the viewing card is physically popping out you may need a new box rather than a card...  (On the basis it's inserted correctly)
Can you not put some tape over it to stop it popping out?  (This will be much easier than a box swap)
Avatar for Claire14
