Discussion topic: Viewing DVR security cameras on Sky Q
This message was authored by: NicholasS
Does anyone know if there is a way to view home security cameras on Sky Q?  We have 3 Sky Q boxes connected to 3 TVs around the house.  I am installing a DVR security camera system.  The DVR box can connect via an HDMI cable to a TV to view images.  However, that would only be available on one TV with the HDMI cable connecting to the TV rather than the Sky Q box.  I'm wonderting if there is a way to connect the HDMI to the Sky Q box so i can see it on the other two Sky Q connected TVs.  I'm assuming there is no HDMI input to Sky Q, so perhaps there is a way to use a connection to my internet router to achive the same?
Thank you!
Nick
Re: Viewing DVR security cameras on Sky Q
Thank you!
Nick
hi @NicholasS
I am afraid not - SKY Q cannot have any video input directly or streamed to it
That would wholly depend on what the DVR system supports - perhaps you can have more than one receiver to plug into each TV?  But you need to look at the support for that system - there's no option to use Q as noted.
@NicholasS
Apart from generating a YouTube feed from the cameras and then using the YouTube app on Q (not entirely impossible, but distinctly impractical) I cannot think of any way to achieve that.
If the TVs are 'smart' then they may be able to host Plex or a similar app which would be a step forward, but you'd still need native IP output from the DVR or some form of external real-time capture, rendering and IP presentation.
Ideally you'd source a DVR which is inherently capable of such a thing.
