4
This discussion topic has been answered Discussion topic: How to attach Sky Q box to the wall behind tv in a media wall.
This message was authored by: JaneBLand
We are fitting a media wall with tv and the SkyQ box will be hidden behind the tv. Firstly, can anybody recommend a bracket for the sky box and secondly, does it matter if it is on its side.
This message was authored by: MightyQuinn Answer
Re: How to attach Sky Q box to the wall behind tv in a media wall.
Hi @JaneBLand   Just search Amazon for sky q main box wall mount. The only really important thing is ventilation.
hi @JaneBLand
It can be done but we don't really recommend main boxes are mounted vertically especially as it affects the heat dissapation (as indicated by @MightyQuinn reply)
You also need to bear in mind that there may be times when your remote needs to have direct line of sight.
Avatar for JaneBLand
Thank you.
Thank you. I will have a look on Amazon and make sure there is plenty of air flow at the back of the tv.
